跳转到主内容
Samsung RF263BEAESR Freezer Door Handle Replacement
你所需要的
  1. Samsung RF263BEAESR Freezer Door Handle Replacement, Freezer Door Handle: 步骤 1 中的图像 1,3 Samsung RF263BEAESR Freezer Door Handle Replacement, Freezer Door Handle: 步骤 1 中的图像 2,3 Samsung RF263BEAESR Freezer Door Handle Replacement, Freezer Door Handle: 步骤 1 中的图像 3,3
    • Use the screwdriver to screw in the door handle opening.
  2. Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 2 中的图像 1,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 2 中的图像 2,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 2 中的图像 3,3
    • Add the screw on the other side of the handle.
  3. Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 3 中的图像 1,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 3 中的图像 2,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 3 中的图像 3,3
    • Use the screw driver to screw in the mounting screw on both sides of the freezer.
  4. Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 4 中的图像 1,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 4 中的图像 2,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 4 中的图像 3,3
    • Use the Allen key to screw in the small bolt on the bottom right side of the handle.
  5. Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 5 中的图像 1,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 5 中的图像 2,3 Samsung RF263BEAESR Freezer Door Handle Replacement: 步骤 5 中的图像 3,3
    • If all done correctly, you will have a functioning door handle.
终点
2等其他人完成本指南。
Al Sadeqe
于10/29/22注册
142 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-3, Briggs Fall 2022 CSU Los Angeles, Team 2-3, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G3
1 名成员
创作了1篇指南
5条评论
The plastic piece that you screw the mounting screw into is broken on our refrigerator. How can I open up the door to replace that plastic piece? Thanks.
Kevin Bosch - 回复
Hi Kevin, were you able to fix the plastic piece. I also have a similar issue where the plastic broke off
Aneesh Nair -
Any leads on where to buy the plastic part?
Mariola - 回复
4mm is too big, I had to use a 2.5 instead.
Smed - 回复
According to Samsung, that 'plastic piece', also known as the Freezer Door Handle Mounting Cap, (the part that the handle mounting stud is attached through), has no part number... "There are not part numbers assigned to these parts as this model doesn’t allow the replacement of them". The only part option Samsung offers is the Freezer Door Assembly, currently about $350 plus Sales Tax and Shipping.
Once your Samsung appliance gets to be more than 2 or 3 years old, Samsung simply has horrible customer support and unreliable parts support for it's products.
Paul Flam - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 57
过去 30 天: 315
总计 6,251
