简介
Cooling fan and heat sink cool off CPU. Faulty cooling fan leads to damaging the CPU and the computer will not function correctly. This guide will show steps to replace cooling fan and heat sink with new ones.
你所需要的
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
另外一个人完成了本指南。
一条评论
Thanks for the graphics. But you missed 3 screws under the battery compartment.
Doing all of this really helped... before, my laptop would just turn off randomly. I'm thinking this was because of overheating.
After this, it hasn't shut down yet.
thank you.
gary.crump - 回复
