跳转到主内容
Samsung Powerbot R9250 Wheel Replacement
你所需要的
  1. Samsung Powerbot R9250 Wheel Replacement, Wheel: 步骤 1 中的图像 1,1
    • Flip the bot onto its side with the wheel you want to remove on top.
  2. Samsung Powerbot R9250 Wheel Replacement: 步骤 2 中的图像 1,1
    • Remove the round white cap on the outside of the wheel.
  3. Samsung Powerbot R9250 Wheel Replacement: 步骤 3 中的图像 1,1
    • Next, pry and remove the white casing that runs around the back round part of the bot.
  4. Samsung Powerbot R9250 Wheel Replacement: 步骤 4 中的图像 1,1
    • Continue until the whole white casing comes off.
  5. Samsung Powerbot R9250 Wheel Replacement: 步骤 5 中的图像 1,1
    • For the wheel you want to remove, there is a small square opening on outer black protective layer still around the wheel. Locate the screw that is inside the whole. Remove this screw.
  6. Samsung Powerbot R9250 Wheel Replacement: 步骤 6 中的图像 1,2 Samsung Powerbot R9250 Wheel Replacement: 步骤 6 中的图像 2,2
    • Pry the black protective layer away from the wheel, and pull the wheel out.
结论
另外一个人完成了本指南。
Ethen Sanchez
于01/24/17注册
552 声望
创作了5篇指南
团队
Cal Poly, Team 10-3, Banghart Winter 2017 Cal Poly, Team 10-3, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G3
3 名成员
创作了10篇指南
一条评论
Hi Ethen. I've recently replaced both wheel kits on the same model powerbot you are working on in this guide. When I turn it on now it becomes absolutely possessed. Goes much faster than normal and moved erratically. I am wondering if you have ever experienced this or have heard of this.
Cameron Curran - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,860
