跳转到主内容
Samsung Powerbot R9250 Battery Replacement
你所需要的
  1. Samsung Powerbot R9250 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom of the bot, locate the battery lid along the curved edge of the bot.
  2. Samsung Powerbot R9250 Battery Replacement: 步骤 2 中的图像 1,2 Samsung Powerbot R9250 Battery Replacement: 步骤 2 中的图像 2,2
    • Unscrew each of the two screws and remove the lid to expose the battery.
  3. Samsung Powerbot R9250 Battery Replacement: 步骤 3 中的图像 1,1
    • Follow the wires to find the small white box next to the battery.
  4. Samsung Powerbot R9250 Battery Replacement: 步骤 4 中的图像 1,1
    • On the side of the white box facing the battery, find the rigid tab.
  5. Samsung Powerbot R9250 Battery Replacement: 步骤 5 中的图像 1,3 Samsung Powerbot R9250 Battery Replacement: 步骤 5 中的图像 2,3 Samsung Powerbot R9250 Battery Replacement: 步骤 5 中的图像 3,3
    • Push this tab into the white box, and pull the wires up. This releases the wire from the white box, allowing you to fully remove the battery.
结论
2等其他人完成本指南。
Ethen Sanchez
于01/24/17注册
552 声望
创作了5篇指南
团队
Cal Poly, Team 10-3, Banghart Winter 2017 Cal Poly, Team 10-3, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G3
3 名成员
创作了10篇指南
4条评论
This is what I needed to know. You are my life saver.
thank you.
Akiko Ohkawa - 回复
How do you know it’s time for a battery replacement? Mine starts up fine, but after 5 minutes suction drops to lowest setting.
James Morgan - 回复
Where can we a get a replacement battery, I could not find one anywhere.
Hari Krishna Gaddipati - 回复
I am looking for one also!
Julie Miller -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 25
总计 3,380
