本指南有最近更改,您可查看未经巡查的最新版本。
简介
Many problems with the functionality of the phone may arise that are beyond a simple battery change, in which case means that the motherboard of the phone may have been compromised. If the screen or the keypad buttons do not work, it is possible that changing the motherboard will directly solve the problem. This guide shows how to access and replace the motherboard of the phone.
你所需要的
Remove the four screws (3 mm) from the battery compartment.
Press the release buttons located on the side of the phone while gently prying the back plate off.
Press the release tabs on the sides of the back casing.
Gently pry the motherboard loose and remove it.
另外一个人完成了本指南。
