当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the battery out from the battery compartment on the back of the phone.
Unscrew the antenna top.
Clasp the antenna with tweezers and push toward the top.
Remove the antenna.
Remove the four screws (3 mm) from the battery compartment.
Press the release buttons located on the side of the phone while gently prying the back plate off.
Press the release tabs on the sides of the back casing.
Gently pry the motherboard loose and remove it.
Remove the gray keypad from the phone by peeling it back.
Remove the black keypad from the phone casing.
Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
取消:我没有完成这个指南。
与2其他贡献者
于03/26/14注册
413 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
CLEM-BENSON-S14S6G2
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 185
