跳转到主内容
简介
If the keypad buttons are not responding or are functioning in a way that is different from their intended purpose, then it is possible that the keypad may be damaged. This guide shows how to check the keypad and, if necessary, replace it.
配件
没有特定配件。
  1. Slide the battery out from the battery compartment on the back of the phone. Slide the battery out from the battery compartment on the back of the phone.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Unscrew the antenna top. Unscrew the antenna top.
    • Unscrew the antenna top.
  3. Clasp the antenna with tweezers and push toward the top. Remove the antenna. Remove the antenna.
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Remove the four screws (3 mm) from the battery compartment. Press the release buttons located on the side of the phone while gently prying the back plate off. Press the release buttons located on the side of the phone while gently prying the back plate off.
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  6. Press the release tabs on the sides of the back casing. Gently pry the motherboard loose and remove it. Gently pry the motherboard loose and remove it.
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  7. Remove the gray keypad from the phone by peeling it back. Remove the gray keypad from the phone by peeling it back. Remove the gray keypad from the phone by peeling it back.
    • Remove the gray keypad from the phone by peeling it back.
  8. Remove the black keypad from the phone casing. Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
    • Remove the black keypad from the phone casing.
    • Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
结论
Barbara
于2014年03月26日注册
413 信誉积分
创作了4篇指南
团队
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G2
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 122
