跳转到主内容
Samsung POWERbot VR9000 Powerbrush Replacement
  1. Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: 步骤 1 中的图像 1,2 Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: 步骤 1 中的图像 2,2
    • Turn off the emergency switch located at the bottom right of the POWERbot.
  2. Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 2 中的图像 1,2 Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 2 中的图像 2,2
    • Press the two yellow tabs immediately below the POWERbrush.
  3. Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 3 中的图像 1,2 Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 3 中的图像 2,2
    • Lift the brush cover, indicated by the yellow strip located above the yellow tabs.
  4. Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 4 中的图像 1,2 Samsung POWERbot VR9000 Powerbrush Replacement: 步骤 4 中的图像 2,2
    • Remove the power brush starting with the unhinged right side of the brush.
结论
Harrison Fugate
于04/24/17注册
102 声望
撰写一个指南
团队
Cal Poly, Team S15-G3, Banghart Spring 2017 Cal Poly, Team S15-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G3
4 名成员
创作了14篇指南
2条评论
The brush is wobbly in position. Is there an insert on the right side of the brush at the bearing. This position, the bearing look too small for the opening of the cover and the upper plastic.
Charlie nguyen - 回复
Did you lose the rubber cover/ washer that goes over the bearing? You can replace it from Samsung if you did.
hawkswhispertwh - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 2,207
