跳转到主内容
简介
Replace the motor to mobilize and restore suction power to your POWERbot. The motor will need to be removed to access the Right Driving Wheel.
配件
没有特定配件。
  1. Turn the emergency switch off.
    • Turn the emergency switch off.
  2. Remove the two exposed screws on the top right of the device. Remove the two exposed screws on the top right of the device.
    • Remove the two exposed screws on the top right of the device.
  3. Lift the cover plate to expose the battery.
    • Lift the cover plate to expose the battery.
  4. Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot.  Pull up to disconnect. Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot.  Pull up to disconnect.
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Lift the battery from the right side, up and out of its compartment. Lift the battery from the right side, up and out of its compartment.
    • Lift the battery from the right side, up and out of its compartment.
  6. Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment. Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. With moderate force, separate the silver top from the black bottom of the vacuum. The cover will only separate a few inches as the two halves are connected by wires.
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side  of the clip, pulling the connector out.
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Remove the four 1.2 cm screws. Remove the single 0.8 cm screw.
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Remove the two 1.5 cm screws on the motor chamber.
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Lift the motor by grabbing the body of the motor, lifting upward. With the screws removed from the motor chamber the top of the motor chamber will pop open.
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
结论
6等其他人完成本指南。
Eric Anderson
于2017年09月11日注册
423 信誉积分
创作了2篇指南
团队
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G8
3 名成员
创作了5篇指南
6条评论
Anybody know where I can get the motor?
donstatus87 - 回复
I'm getting a Power brush error. Does the motor contain the power brush square socket and gearing?
Steve.
Steven Nicholas - 回复
One can actually open up the motor housing and take out the metal motor. Be careful not to break the clips when opening the housing… because I did…. but duct tape will prolly hold it together again. Anyway , the motor bears the following markings in my R7040: VCM-140CLDA DC21.6V 145W 2018.5.22-12.50
Have fun!
websites140 - 回复
Easy to replace and found a refurbished motor on eBay.
David Trinkle - 回复
Thanks for this guide! My motor was making a high pitched whine and grind - bought a replacement refurb motor on eBay for $39; hope it works.
joey - 回复
Hi. I have a very important question. vr7040 also has 10w motor, can i replace this motor with other vr7065 vr7070 engine? Is there a problem with the electronic circuit?
Hulusi Şen - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 43
总计 3,078
