简介
Replace the motor to mobilize and restore suction power to your POWERbot. The motor will need to be removed to access the Right Driving Wheel.
你所需要的
Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
Remove the two 1.5 cm screws above the yellow sliding lock tabs.
Remove the two 1.2 cm screws in the brush compartment.
Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
how do you pinch the top and the bottom when the bottom seems to be glued to the motherboard?
8等其他人完成本指南。
6条评论
Anybody know where I can get the motor?
I'm getting a Power brush error. Does the motor contain the power brush square socket and gearing?
Steve.
One can actually open up the motor housing and take out the metal motor. Be careful not to break the clips when opening the housing… because I did…. but duct tape will prolly hold it together again. Anyway , the motor bears the following markings in my R7040: VCM-140CLDA DC21.6V 145W 2018.5.22-12.50
Have fun!
Easy to replace and found a refurbished motor on eBay.
Hi. I have a very important question. vr7040 also has 10w motor, can i replace this motor with other vr7065 vr7070 engine? Is there a problem with the electronic circuit?
Hulusi Şen - 回复
