简介
Replace the left driving wheel of your POWERbot to end movement problems. To resolve the C 02 error code, replace the left driving wheel.
你所需要的
Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
Remove the two 1.5 cm screws above the yellow sliding lock tabs.
Remove the two 1.2 cm screws in the brush compartment.
Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
how do you pinch the top and the bottom when the bottom seems to be glued to the motherboard?
Unscrew the two screws securing the left and right ends of the wheel casing to the base of the vacuum.
5等其他人完成本指南。
2条评论
Where can you find the replacement left driving wheel? are all the model the same?
My left wheel seams to have sand in the gear box now and won’t turn. I need a replacement part or assembly for a R7065 Powerbot LH wheel gear box, which is very similar to the R7070. As far as I can see (I have one of each) the R7065 has two rubber beaters and two brush beaters where as the R7070 has 4 rubber beaters.
