跳转到主内容
Samsung PL200 SD card Replacement
  1. Samsung PL200 SD card Replacement, SD card: 步骤 1 中的图像 1,2 Samsung PL200 SD card Replacement, SD card: 步骤 1 中的图像 2,2
    • Push the battery cover over to access battery/SD card compartment on the bottom.
    • There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
  2. Samsung PL200 SD card Replacement: 步骤 2 中的图像 1,2 Samsung PL200 SD card Replacement: 步骤 2 中的图像 2,2
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector to raise SD card.
    • Use your fingers to remove the old SD card.
    • Insert the new SD card into the SD card slot and push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
结论
另外一个人完成了本指南。
Jacob Presnell
于01/29/15注册
219 声望
创作了2篇指南
团队
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S15G7
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 447
