跳转到主内容
加入维修社区 - 创建账户
Samsung PL200 Battery Replacement
  1. Samsung PL200 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung PL200 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
  2. Samsung PL200 Battery Replacement: 步骤 2 中的图像 1,3 Samsung PL200 Battery Replacement: 步骤 2 中的图像 2,3 Samsung PL200 Battery Replacement: 步骤 2 中的图像 3,3
    • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
    • This will release the spring loaded battery.
    • Use your fingers to remove the old battery.
  3. Samsung PL200 Battery Replacement: 步骤 3 中的图像 1,3 Samsung PL200 Battery Replacement: 步骤 3 中的图像 2,3 Samsung PL200 Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the new battery into the battery slot.
    • Push it down with your finger until the blue release switch re-engages over top of the battery.
    • Close the battery/SD card compartment.
结论
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
Austin Fitzpatrick
于01/29/15注册
110 声望
撰写一个指南
团队
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S15G7
5 名成员
创作了10篇指南
2指南评论
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
Reginald Parker - 回复
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 50
总计 1,797
