跳转到主内容
Samsung PL20 Lens Replacement
你所需要的
  1. Samsung PL20 Lens Replacement, Lens: 步骤 1 中的图像 1,3 Samsung PL20 Lens Replacement, Lens: 步骤 1 中的图像 2,3 Samsung PL20 Lens Replacement, Lens: 步骤 1 中的图像 3,3
    • Remove the battery and the memory card from the device.
    • Remove the two screws on the side of the device, to the left of the camera lens.
  2. Samsung PL20 Lens Replacement: 步骤 2 中的图像 1,3 Samsung PL20 Lens Replacement: 步骤 2 中的图像 2,3 Samsung PL20 Lens Replacement: 步骤 2 中的图像 3,3
    • Remove the single screw from the bottom of the device.
    • Remove the two screws on the side of the the device, to the right of the camera lens.
    • Using a plastic opening tool, pry the outside casing apart. Start from the battery compartment and work around the seem of the casing.
  3. Samsung PL20 Lens Replacement: 步骤 3 中的图像 1,3 Samsung PL20 Lens Replacement: 步骤 3 中的图像 2,3 Samsung PL20 Lens Replacement: 步骤 3 中的图像 3,3
    • Remove the back panel, revealing the LCD screen.
    • Pull the LCD screen out of its holder. Once you have access to the connecting strip, flip the clip upwards releasing the screen completely and remove.
  4. Samsung PL20 Lens Replacement: 步骤 4 中的图像 1,3 Samsung PL20 Lens Replacement: 步骤 4 中的图像 2,3 Samsung PL20 Lens Replacement: 步骤 4 中的图像 3,3
    • Gently pull the front panel from the device.
    • Remove the two screws attaching the LCD screen holder to the device.
    • Remove the screen holder from the rest of the device.
  5. Samsung PL20 Lens Replacement: 步骤 5 中的图像 1,3 Samsung PL20 Lens Replacement: 步骤 5 中的图像 2,3 Samsung PL20 Lens Replacement: 步骤 5 中的图像 3,3
    • Flip the grey clip upwards, releasing the connector from the device.
    • Disconnect the ribbon cable extending from the left side.
    • Disconnect the ribbon cable extending from the button bar.
    • Remove the 2 screws.
  6. Samsung PL20 Lens Replacement: 步骤 6 中的图像 1,3 Samsung PL20 Lens Replacement: 步骤 6 中的图像 2,3 Samsung PL20 Lens Replacement: 步骤 6 中的图像 3,3
    • Remove these 3 screws. releasing the lens from the logic board.
    • Remove the lens from the logic board.
结论
另外一个人完成了本指南。
oldturkey03
于09/29/10注册
817,878 声望
创作了119篇指南
2指南评论
Beware there is a capacitor that stores a charge even when the battery is removed. On my camera i touched it, it created a short circuit, i got a shock, and it killed my camera.
morrisettema - 回复
如果螺丝不慎遗失应该买多大的
742339702@qq.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 3,278
