跳转到主内容
Samsung Odyssey NP800G5M Speaker Replacement
你所需要的
  1. Samsung Odyssey NP800G5M Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 2 中的图像 2,2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 3 中的图像 1,2 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Samsung Odyssey NP800G5M Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Samsung Odyssey NP800G5M Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Using the spudger, lift the black tab to release the ribbon cable.
    • Disconnect the USB ribbon cable.
  6. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 6 中的图像 1,2 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the tape securing the wire down.
    • This tape will remain sticky after removal.
  7. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 7 中的图像 2,2
    • Disconnect the speakers by pulling the plugs out of their sockets.
  8. Samsung Odyssey NP800G5M Speaker Replacement: 步骤 8 中的图像 1,3 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 8 中的图像 2,3 Samsung Odyssey NP800G5M Speaker Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the four screws holding the speakers to device.
    • Remove the speakers from the device.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 414
