跳转到主内容
Samsung Odyssey NP800G5M Fan Replacement
你所需要的
  1. Samsung Odyssey NP800G5M Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Fan Replacement: 步骤 2 中的图像 1,2 Samsung Odyssey NP800G5M Fan Replacement: 步骤 2 中的图像 2,2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Fan Replacement: 步骤 3 中的图像 1,2 Samsung Odyssey NP800G5M Fan Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Fan Replacement: 步骤 4 中的图像 1,3 Samsung Odyssey NP800G5M Fan Replacement: 步骤 4 中的图像 2,3 Samsung Odyssey NP800G5M Fan Replacement: 步骤 4 中的图像 3,3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Fan Replacement, Fan: 步骤 5 中的图像 1,3 Samsung Odyssey NP800G5M Fan Replacement, Fan: 步骤 5 中的图像 2,3 Samsung Odyssey NP800G5M Fan Replacement, Fan: 步骤 5 中的图像 3,3
    • Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
    • Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
    • Using the same screwdriver, unscrew the six screws surrounding the heat sink.
    • These screws cannot be removed from the device.
    • Remove the fan assembly from the device.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,220
