跳转到主内容
Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement
你所需要的
  1. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 1,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 2,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the cover plate in place.
  7. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • Remove the black ribbon cable by pulling up on the black cover and sliding out the cable.
  8. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 8 中的图像 1,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 8 中的图像 2,3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 8 中的图像 3,3
    • Remove the three black and white cables by gently pulling on them.
  9. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 9 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the USB board down and remove the board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 594
