跳转到主内容
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
你所需要的
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 2 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 3 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 4 中的图像 1,2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 5 中的图像 1,3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 5 中的图像 2,3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: 步骤 6 中的图像 1,1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 步骤 8 中的图像 1,1
    • Pull the hard drive away from the cradle and remove it from the device.
结论
另外一个人完成了本指南。
2指南评论
Would you point out where the SSD slot would be?
aroyphillips - 回复
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 34
总计 3,974
