跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Jammed button can cause prohibit the camera to function or do what you want it to. The whole encasement needs to be replace and is easier to do as opposed to fixing one single button.
  1. Pull the switch on the bottom of the camera back with your thumb. Pull the switch on the bottom of the camera back with your thumb.
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Push second switch(blue) forward with your thumb. Push second switch(blue) forward with your thumb.
    • Push second switch(blue) forward with your thumb.
  3. Pull out battery.
    • Pull out battery.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Open the screen exposing the hinge cover and place the plastic opening tool inside. Pry the hinge cover up by moving the plastic opening tool in a downward motion. Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  6. Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver. Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver. In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  7. Use the plastic opening tool in a downward motion around each side of the camera  to pry the casing open. The casing should be removed easily; you shouldn't have to use much force.
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  8. Locate the black ribbon at the bottom left of the camera's interior. Place the plastic opening tool under the black ribbon connector.
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
结论
carter grenewicz
于2016年09月15日注册
204 信誉积分
创作了2篇指南
团队
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G5
3 名成员
创作了6篇指南
your dumb. idot
Nick Furio - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 14
总计 593
