跳转到主内容
Samsung NX500 Screen Side Encasement Replacement
你所需要的
  1. Samsung NX500 Screen Side Encasement Replacement, Battery: 步骤 1 中的图像 1,2 Samsung NX500 Screen Side Encasement Replacement, Battery: 步骤 1 中的图像 2,2
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Side Encasement Replacement: 步骤 2 中的图像 1,2 Samsung NX500 Screen Side Encasement Replacement: 步骤 2 中的图像 2,2
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Side Encasement Replacement: 步骤 3 中的图像 1,1
    • Pull out battery.
  4. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 步骤 4 中的图像 1,3 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 步骤 4 中的图像 2,3 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 步骤 4 中的图像 3,3
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Side Encasement Replacement: 步骤 5 中的图像 1,3 Samsung NX500 Screen Side Encasement Replacement: 步骤 5 中的图像 2,3 Samsung NX500 Screen Side Encasement Replacement: 步骤 5 中的图像 3,3
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Side Encasement Replacement: 步骤 6 中的图像 1,2 Samsung NX500 Screen Side Encasement Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Side Encasement Replacement: 步骤 7 中的图像 1,2 Samsung NX500 Screen Side Encasement Replacement: 步骤 7 中的图像 2,2
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
结论
carter grenewicz
于09/15/16注册
204 声望
创作了2篇指南
团队
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G5
3 名成员
创作了12篇指南
一条评论
your dumb. idot
Nick Furio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 931
