跳转到主内容
加入维修社区 - 创建账户
Samsung NX300 and NX300M Back Panel Assembly Replacement
你所需要的
  1. Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 步骤 1 中的图像 1,2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 步骤 1 中的图像 2,2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
  2. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Input Port Screw: 步骤 2 中的图像 1,1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
  3. Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 步骤 3 中的图像 1,3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 步骤 3 中的图像 2,3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 步骤 3 中的图像 3,3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  4. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 步骤 4 中的图像 1,3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 步骤 4 中的图像 2,3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
结论
11等其他人完成本指南。
Andres Perez
于01/21/15注册
999 声望
创作了5篇指南
团队
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G6
4 名成员
创作了12篇指南
2指南评论
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Amanda Aiken - 回复 分享
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
Norbert - Ciprian Patras - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 78
总计 5,612
