跳转到主内容
加入维修社区 - 创建账户
Samsung NX300 Rear Menu Button Replacement
你所需要的
  1. Samsung NX300 Rear Menu Button Replacement, Unscrew the Back Panel: 步骤 1 中的图像 1,2 Samsung NX300 Rear Menu Button Replacement, Unscrew the Back Panel: 步骤 1 中的图像 2,2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
    询问修复机器人
    添加评论
  2. Samsung NX300 Rear Menu Button Replacement, Remove the Input Port Screw: 步骤 2 中的图像 1,1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
    添加评论
  3. Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 步骤 3 中的图像 1,3 Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 步骤 3 中的图像 2,3 Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 步骤 3 中的图像 3,3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
    询问修复机器人
    添加评论
  4. Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 步骤 4 中的图像 1,3 Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 步骤 4 中的图像 2,3 Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
    添加评论
  5. Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 步骤 5 中的图像 1,3 Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 步骤 5 中的图像 2,3 Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a Phillips #00 precision screwdriver, remove the four 1mm screws that are holding the black supports to the panel.
    • Remove the little ribbon tab from the contact pad using tweezers or your fingers, then peel off the black ribbon from the metallic panel.
    • Feed the ribbon through the slot on the back panel to free the LCD Screen. You need to bend the ribbon to get the small tabs through it.
    询问修复机器人
    添加评论
  6. Samsung NX300 Rear Menu Button Replacement, Remove the Metallic Panel: 步骤 6 中的图像 1,2 Samsung NX300 Rear Menu Button Replacement, Remove the Metallic Panel: 步骤 6 中的图像 2,2
    • Using a Phillips #00 precision screwdriver, remove the five 3mm screws.
    • Using a plastic opening tool, slowly lift up the entire metal piece from the back of the camera.
    • If the panel has never been removed from the camera before, it will be glued firmly to the back panel and will require some force to remove. To prevent breaking the back panel, work the plastic opening tool under different areas of the metal plate until it is completely released.
    • There are two small magnetic blocks housed underneath the metallic plate. These are for securing the swivel screen in place while it is closed.
    询问修复机器人
    添加评论
  7. Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 步骤 7 中的图像 1,3 Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 步骤 7 中的图像 2,3 Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 步骤 7 中的图像 3,3
    • Once you remove the metallic panel, peel off the black pad from the buttons using tweezers.
    • Using tweezers, remove any button you need to by pulling on the plastic strips near the connection point to the back panel.
    • If most of the menu buttons need to be replaced, it is better to replace all of the buttons, since the plastic connector pieces break easily during removal.
    询问修复机器人
    添加评论
  8. Samsung NX300 Rear Menu Button Replacement, Free Buttons: 步骤 8 中的图像 1,1
    • The menu buttons are now free from the camera.
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Andres Perez
于01/21/15注册
1,023 声望
创作了5篇指南
团队
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G6
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 25
总计 1,840
