跳转到主内容
加入维修社区 - 创建账户
Samsung NX30 Screen Replacement
你所需要的
  1. Samsung NX30 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the camera over so that the bottom of the camera is up.
    • Push the battery switch towards the back of the camera.
  2. Samsung NX30 Screen Replacement: 步骤 2 中的图像 1,2 Samsung NX30 Screen Replacement: 步骤 2 中的图像 2,2
    • Locate the blue switch above the battery pack.
    • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
  3. Samsung NX30 Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Samsung NX30 Screen Replacement, Screen: 步骤 4 中的图像 1,3 Samsung NX30 Screen Replacement, Screen: 步骤 4 中的图像 2,3 Samsung NX30 Screen Replacement, Screen: 步骤 4 中的图像 3,3
    • Unscrew the nine 4mm Phillips head screws surrounding the body of the camera. They are located on the bottom of the camera and both sides of the camera.
  5. Samsung NX30 Screen Replacement: 步骤 5 中的图像 1,3 Samsung NX30 Screen Replacement: 步骤 5 中的图像 2,3 Samsung NX30 Screen Replacement: 步骤 5 中的图像 3,3
    • Pull the viewer out from the camera and then up.
    • Unscrew the two black 4mm Phillips head screws under it.
  6. Samsung NX30 Screen Replacement: 步骤 6 中的图像 1,2 Samsung NX30 Screen Replacement: 步骤 6 中的图像 2,2
    • Once the screws are all removed, place the camera face down, with the screen facing up.
    • Pry open the body using the plastic opening tool.
    • Gently open the body.
  7. Samsung NX30 Screen Replacement: 步骤 7 中的图像 1,2 Samsung NX30 Screen Replacement: 步骤 7 中的图像 2,2
    • Then use the plastic opening tool to dislodge the Ribbon Cable, located near the top of the camera, from the Circuit Board.
    • The Ribbon Cable will be disconnected from the Circuit Board when you are done.
结论
另外一个人完成了本指南。
Julia Kilcup
于02/03/16注册
431 声望
创作了3篇指南
团队
UW Tacoma, Team 1-4, Rose Winter 2016 UW Tacoma, Team 1-4, Rose Winter 2016 的会员
UWT-ROSE-W16S1G4
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 21
总计 2,169
