跳转到主内容
Samsung NX2000 Menu Buttons Replacement
你所需要的
  1. Samsung NX2000 Menu Buttons Replacement, LCD: 步骤 1 中的图像 1,1
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
  2. Samsung NX2000 Menu Buttons Replacement: 步骤 2 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement: 步骤 2 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  3. Samsung NX2000 Menu Buttons Replacement: 步骤 3 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement: 步骤 3 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement: 步骤 3 中的图像 3,3
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
  4. Samsung NX2000 Menu Buttons Replacement: 步骤 4 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement: 步骤 4 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement: 步骤 4 中的图像 3,3
    • Separate the LCD half compartment of the camera from the main body.
  5. Samsung NX2000 Menu Buttons Replacement: 步骤 5 中的图像 1,1
    • Remove the four 1mm screws with the Y0 screwdriver.
  6. Samsung NX2000 Menu Buttons Replacement: 步骤 6 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement: 步骤 6 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  7. Samsung NX2000 Menu Buttons Replacement: 步骤 7 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement: 步骤 7 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement: 步骤 7 中的图像 3,3
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
  8. Samsung NX2000 Menu Buttons Replacement: 步骤 8 中的图像 1,1
    • The LCD screen is now separated form the main frame.
  9. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 步骤 9 中的图像 1,3 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 步骤 9 中的图像 2,3 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the tweezers to pull out the home and playback buttons from the camera frame.
  10. Samsung NX2000 Menu Buttons Replacement: 步骤 10 中的图像 1,1
    • Remove the home buttons from the camera frame.
结论
另外一个人完成了本指南。
Katarina Raic
于02/09/16注册
288 声望
创作了2篇指南
团队
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 568
