跳转到主内容
Samsung NX2000 Lens Assembly Replacement
你所需要的
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: 步骤 2 中的图像 1,3 Samsung NX2000 Lens Assembly Replacement: 步骤 2 中的图像 2,3 Samsung NX2000 Lens Assembly Replacement: 步骤 2 中的图像 3,3
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: 步骤 3 中的图像 1,3 Samsung NX2000 Lens Assembly Replacement: 步骤 3 中的图像 2,3 Samsung NX2000 Lens Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: 步骤 4 中的图像 1,3 Samsung NX2000 Lens Assembly Replacement: 步骤 4 中的图像 2,3 Samsung NX2000 Lens Assembly Replacement: 步骤 4 中的图像 3,3
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
结论
另外一个人完成了本指南。
Katarina Raic
于02/09/16注册
288 声望
创作了2篇指南
团队
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 872
