跳转到主内容
加入维修社区 - 创建账户
Samsung NX2000 Battery Replacement
  1. Samsung NX2000 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the camera upside down with the lens facing you.
  2. Samsung NX2000 Battery Replacement: 步骤 2 中的图像 1,1
    • Locate the sliding latch on the right side of the camera and slide the latch to the left side to open up the battery compartment.
  3. Samsung NX2000 Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the blue release lever holding the battery down. Slide the blue lever to the right to release the battery itself.
  4. Samsung NX2000 Battery Replacement: 步骤 4 中的图像 1,1
    • The battery will now slide up about an inch allowing the battery to be pulled out of the camera.
  5. Samsung NX2000 Battery Replacement: 步骤 5 中的图像 1,1
    • Insert the new battery with the arrow on the battery pointing into the camera. The red square indicates the location of the arrow.
结论
另外一个人完成了本指南。
David Edbom
于02/09/16注册
119 声望
撰写一个指南
团队
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 1,213
