简介
This guide will show you how to replace the motherboard in the camera. Be sure to turn off the camera and remove the battery before you being your replacement.
你所需要的
Locate the bottom panel of the camera.
Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
Remove the black rubber tape with the plastic opening tool and slowly peel it off.
即将完成!
结论
另外一个人完成了本指南。
