本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your menu button is not working properly or sticking or is even chipped or cracked and you wish to replace it here is the guide needed. Make sure you turn off the camera and remove the battery before you begin the replacement.
你所需要的
Locate the bottom panel of the camera.
Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
另外一个人完成了本指南。
