跳转到主内容
Samsung NX1000 Menu Button Replacement
你所需要的
  1. Samsung NX1000 Menu Button Replacement, Removing the Back Panel: 步骤 1 中的图像 1,1
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Samsung NX1000 Menu Button Replacement: 步骤 2 中的图像 1,2 Samsung NX1000 Menu Button Replacement: 步骤 2 中的图像 2,2
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Samsung NX1000 Menu Button Replacement: 步骤 3 中的图像 1,2 Samsung NX1000 Menu Button Replacement: 步骤 3 中的图像 2,2
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Samsung NX1000 Menu Button Replacement: 步骤 4 中的图像 1,2 Samsung NX1000 Menu Button Replacement: 步骤 4 中的图像 2,2
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Samsung NX1000 Menu Button Replacement: 步骤 5 中的图像 1,3 Samsung NX1000 Menu Button Replacement: 步骤 5 中的图像 2,3 Samsung NX1000 Menu Button Replacement: 步骤 5 中的图像 3,3
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Samsung NX1000 Menu Button Replacement: 步骤 6 中的图像 1,2 Samsung NX1000 Menu Button Replacement: 步骤 6 中的图像 2,2
    • Completely separate the back panel from the camera.
  7. Samsung NX1000 Menu Button Replacement, Back Panel Components: 步骤 7 中的图像 1,2 Samsung NX1000 Menu Button Replacement, Back Panel Components: 步骤 7 中的图像 2,2
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  8. Samsung NX1000 Menu Button Replacement: 步骤 8 中的图像 1,3 Samsung NX1000 Menu Button Replacement: 步骤 8 中的图像 2,3 Samsung NX1000 Menu Button Replacement: 步骤 8 中的图像 3,3
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  9. Samsung NX1000 Menu Button Replacement: 步骤 9 中的图像 1,1
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  10. Samsung NX1000 Menu Button Replacement, Menu Button: 步骤 10 中的图像 1,1
    • Remove the button assembly from the back panel
结论
另外一个人完成了本指南。
Yesenia
于01/22/15注册
717 声望
创作了6篇指南
团队
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G13
4 名成员
创作了14篇指南
1指南评论
Has anyone gotten insight into remove/recondition the on/off switch and dial?
dgourlay - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 1,990
