当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
Use a plastic opening tool to separate the back cover from the front cover.
Pry the back cover in this order: bottom, right side, left side.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
