跳转到主内容
加入维修社区 - 创建账户
Samsung NX1 Back Cover Replacement
你所需要的
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: 步骤 1 中的图像 1,2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: 步骤 1 中的图像 2,2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: 步骤 2 中的图像 1,2 Samsung NX1 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,3 Samsung NX1 Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,3 Samsung NX1 Back Cover Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: 步骤 4 中的图像 1,2 Samsung NX1 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: 步骤 7 中的图像 1,3 Samsung NX1 Back Cover Replacement: 步骤 7 中的图像 2,3 Samsung NX1 Back Cover Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: 步骤 8 中的图像 1,2 Samsung NX1 Back Cover Replacement: 步骤 8 中的图像 2,2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: 步骤 9 中的图像 1,3 Samsung NX1 Back Cover Replacement: 步骤 9 中的图像 2,3 Samsung NX1 Back Cover Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
结论
另外一个人完成了本指南。
Hannah Patrick
于02/24/16注册
903 声望
创作了6篇指南
团队
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 16
总计 1,214
