跳转到主内容
Samsung NT300E5X-AD5S Hard Drive Replacement
你所需要的
  1. Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 步骤 1 中的图像 1,3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 步骤 1 中的图像 2,3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 步骤 1 中的图像 3,3
    • Place the laptop with the backside facing up.
    • Remove the battery from the device by pushing out the slide locks to either end.
    • When reassembling the battery, you only need to push it back into its position.
  2. Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 2 中的图像 1,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 2 中的图像 2,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #00 screwdriver, loosen the 4 mm screw.
    • Remove the ODD/HDD/Memory panel by pushing it towards you.
  3. Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 3 中的图像 1,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 3 中的图像 2,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws.
    • Carefully lift the mounting bracket out of the laptop.
  4. Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 4 中的图像 1,2 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Hold the base of the connector under the hard drive disk (HDD).
    • Gently pull out the connector and separate the HDD from the device.
  5. Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 5 中的图像 1,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 5 中的图像 2,3 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws from the mounting bracket.
    • Take off the HDD from the mounting bracket.
  6. Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 6 中的图像 1,2 Samsung NT300E5X-AD5S Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Put the new HDD or solid state drive (SSD) onto the mounting bracket and secure the new drive using the Phillips #00 screwdriver to replace the four 4 mm screws.
结论
To reassemble your device, follow these instructions in reverse order. Turn on the laptop, and enter the BIOS setup by pressing the F2 button on the keyboard during the initial booting screen. Check the new drive at the section called "SATA Port 1".
另外一个人完成了本指南。
Yeonjong Choi
于05/11/20注册
160 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 908
