跳转到主内容
Samsung NP900X4B Fan Replacement
你所需要的
  1. Samsung NP900X4B Fan Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung NP900X4B Fan Replacement, Back Panel: 步骤 1 中的图像 2,2
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: 步骤 2 中的图像 1,1
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: 步骤 3 中的图像 1,2 Samsung NP900X4B Fan Replacement: 步骤 3 中的图像 2,2
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: 步骤 4 中的图像 1,2 Samsung NP900X4B Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: 步骤 5 中的图像 1,1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: 步骤 6 中的图像 1,2 Samsung NP900X4B Fan Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: 步骤 7 中的图像 1,1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
结论
另外一个人完成了本指南。
Brian Miller
于10/17/18注册
333 声望
创作了2篇指南
团队
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S4G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 178
