跳转到主内容
Samsung NP700Z5AH Optical Drive Replacement
你所需要的
  1. Samsung NP700Z5AH Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Optical Drive Replacement: 步骤 2 中的图像 1,3 Samsung NP700Z5AH Optical Drive Replacement: 步骤 2 中的图像 2,3 Samsung NP700Z5AH Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Optical Drive Replacement: 步骤 3 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Optical Drive Replacement: 步骤 4 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Optical Drive Replacement: 步骤 6 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  7. Samsung NP700Z5AH Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 2,2
    • Using your fingers, grasp the ribbon cable connected to the optical drive and pull it straight out to disconnect it.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  8. Samsung NP700Z5AH Optical Drive Replacement: 步骤 8 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 8 中的图像 2,2
    • Using the Phillips#00 remove the three 3.5mm screws that secure the speaker to the bottom case.
  9. Samsung NP700Z5AH Optical Drive Replacement: 步骤 9 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 9 中的图像 2,2
    • With your fingers, grasp the edges of the speaker and slide it up and away from the fan to lift it out of the case.
  10. Samsung NP700Z5AH Optical Drive Replacement: 步骤 10 中的图像 1,3 Samsung NP700Z5AH Optical Drive Replacement: 步骤 10 中的图像 2,3 Samsung NP700Z5AH Optical Drive Replacement: 步骤 10 中的图像 3,3
    • With the Phillips#00, remove the following screws holding the optical drive to the metal brackets.
    • Six 2.4mm screws
    • One 3.4mm screw
    • Using your fingers, grasp the metal brackets and remove them.
  11. Samsung NP700Z5AH Optical Drive Replacement: 步骤 11 中的图像 1,2 Samsung NP700Z5AH Optical Drive Replacement: 步骤 11 中的图像 2,2
    • Place your fingers on either side of the optical drive and slide it away from the fan to remove it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 458
