跳转到主内容
Samsung NP530U4BL Hard Drive Replacement
你所需要的
  1. Samsung NP530U4BL Hard Drive Replacement, Removing Back Cover: 步骤 1 中的图像 1,1
    • Before disassembling your computer, make sure it is powered off.
    • Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
    • Removing these screws allows you to take off the panel on the right side of the laptop.
  2. Samsung NP530U4BL Hard Drive Replacement: 步骤 2 中的图像 1,2 Samsung NP530U4BL Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Using your dominant hand, pinch the tab on the back panel to the right and remove it.
    • Using the Phillips #00 screwdriver, remove the two 1.5 mm screws that are under the panel.
    • You are now able to detach the entire back cover of the laptop. You can store these screws in the same area as the others because they are all 1.5 mm, identical parts.
  3. Samsung NP530U4BL Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Be sure that you are looking at the laptop so that the spine connecting the base to the screen is at the top.
    • When using the plastic opening tool, be careful not to rip or pull too hard to disengage the prongs connecting the back cover to the base. Moving slowly will make this task easier and less likely to cause damage to your machine.
    • Using the plastic opening tool, start in the upper-left hand corner of the laptop and pry horizontally to the upper right-hand corner.
  4. Samsung NP530U4BL Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Again starting in the upper left-hand corner, pry down vertically towards the bottom left-hand corner of the laptop.
    • You have now disengaged two of the four sides holding the back cover onto the base.
  5. Samsung NP530U4BL Hard Drive Replacement: 步骤 5 中的图像 1,2 Samsung NP530U4BL Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Using your dominant hand, grasp the left side of the back cover and gently pull it up. This should disengage the prongs on the bottom and right edge of the base.
    • The right side of the cover has openings that go around the USB ports, the HDMI port, the Ethernet port, the VGA port, and the headphone jack. Use caution when disengaging the prongs around these parts.
    • After completing this step the entire back cover should be separated from the base, and the inside of the laptop should be revealed.
  6. Samsung NP530U4BL Hard Drive Replacement: 步骤 6 中的图像 1,2 Samsung NP530U4BL Hard Drive Replacement: 步骤 6 中的图像 2,2
    • All steps following the removal of the back cover should be completed while wearing an Anti static bracelet. This prevents ESD (electrostatic discharge). ESD can damage nearly every part on the inside of your computer.
  7. Samsung NP530U4BL Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 Samsung NP530U4BL Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Hard Drive (not pictured)
    • Using your dominant hand, unplug the hard drive from its SATA plug. Once unplugged, the hard drive is an independent piece from the laptop.
  8. Samsung NP530U4BL Hard Drive Replacement: 步骤 8 中的图像 1,1
    • When handling the hard drive, do so carefully. Dropping or banging the hard drive can risk serious damage to the part.
    • Carefully lift the hard drive vertically out of its place.
结论
另外一个人完成了本指南。
Kayla Loycano
于03/02/16注册
889 声望
创作了6篇指南
团队
UMass Dartmouth, Team 8-1, Botvin Spring 2016 UMass Dartmouth, Team 8-1, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,251
