简介
The speaker is responsible for the output of audio from the device. Signs of a faulty speaker could be no or distorted audio. This guide will show you how to replace it properly.
你所需要的
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
另外一个人完成了本指南。
