跳转到主内容
Samsung NP510R5E-A01UB Display Replacement
你所需要的
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: 步骤 2 中的图像 1,1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: 步骤 3 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 3 中的图像 2,2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: 步骤 4 中的图像 1,3 Samsung NP510R5E-A01UB Display Replacement, Display: 步骤 4 中的图像 2,3 Samsung NP510R5E-A01UB Display Replacement, Display: 步骤 4 中的图像 3,3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: 步骤 5 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 5 中的图像 2,2
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: 步骤 6 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 6 中的图像 2,2
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: 步骤 7 中的图像 1,3 Samsung NP510R5E-A01UB Display Replacement: 步骤 7 中的图像 2,3 Samsung NP510R5E-A01UB Display Replacement: 步骤 7 中的图像 3,3
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: 步骤 8 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: 步骤 9 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 9 中的图像 2,2
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: 步骤 10 中的图像 1,2 Samsung NP510R5E-A01UB Display Replacement: 步骤 10 中的图像 2,2
    • Disconnect the last cable by pulling straight out.
结论
Dominic Simpson
于02/14/18注册
245 声望
撰写一个指南
团队
USF Tampa, Team S6-G5, Eyestone Spring 2018 USF Tampa, Team S6-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 682
