简介
The cooling fan is needed to keep the processor within an operable temperature, if it breaks or isn’t working correctly you could fry the processor and/or motherboard. If the fan isn’t working or is too noisy you will need to replace it, which is what this guide shows you how to do.
你所需要的
Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
另外一个人完成了本指南。
