简介
This guide will show how to remove the OD/HDD/Memory panel on the bottom of the laptop. Removing this panel gives access to multiple components in the computer.
你所需要的
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
Locate the ODD/HDD/Memory panel.
Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
Slide the ODD/HDD/Memory panel away from the device to remove it.
即将完成!
结论
