跳转到主内容
Samsung NP350V5C-T02US RAM Replacement
你所需要的
  1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: 步骤 1 中的图像 1,1
    • Flip the laptop over so that the bottom is facing toward you.
  2. Samsung NP350V5C-T02US RAM Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
  3. Samsung NP350V5C-T02US RAM Replacement: 步骤 3 中的图像 1,1
    • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
  4. Samsung NP350V5C-T02US RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Locate the RAM in the lower right hand corner.
  5. Samsung NP350V5C-T02US RAM Replacement: 步骤 5 中的图像 1,1
    • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
    • Since there are two RAMs, remove the other one by using the same method.
  6. Samsung NP350V5C-T02US RAM Replacement: 步骤 6 中的图像 1,1
    • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
结论
一条评论
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 967
