跳转到主内容
Samsung NP350E5C-A02US Optical Drive Replacement
你所需要的
  1. Samsung NP350E5C-A02US Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Optical Drive Replacement: 步骤 3 中的图像 1,1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Optical Drive Replacement, Hard drive and memory stick cover: 步骤 4 中的图像 1,1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 1,1
    • Find the screw between the hard drive and the model label. Then remove the M2.5X5 screw with a Phillips #0 screwdriver.
  8. Samsung NP350E5C-A02US Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Pull the optical drive straight out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 213
