跳转到主内容
你所需要的
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: 步骤 3 中的图像 1,2 Samsung NP305E5A-A03US RAM Replacement: 步骤 3 中的图像 2,2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: 步骤 5 中的图像 1,2 Samsung NP305E5A-A03US RAM Replacement: 步骤 5 中的图像 2,2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: 步骤 8 中的图像 1,2 Samsung NP305E5A-A03US RAM Replacement: 步骤 8 中的图像 2,2
    • Pull out the RAM towards you to remove it from the laptop.
结论
2等其他人完成本指南。
Julia Dotter
于2016年10月31日注册
221 声望
撰写一个指南
团队
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G7
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 345
