跳转到主内容
Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: 步骤 2 中的图像 1,1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: 步骤 3 中的图像 1,2 Samsung NP305E5A-A03US Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
结论
3等其他人完成本指南。
Kris Stobbe
于10/30/16注册
585 声望
创作了3篇指南
团队
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G7
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 498
