跳转到主内容
Samsung NP300E5C Hard Drive Replacement
你所需要的
  1. Samsung NP300E5C Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: 步骤 2 中的图像 1,3 Samsung NP300E5C Hard Drive Replacement: 步骤 2 中的图像 2,3 Samsung NP300E5C Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: 步骤 4 中的图像 1,3 Samsung NP300E5C Hard Drive Replacement: 步骤 4 中的图像 2,3 Samsung NP300E5C Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: 步骤 5 中的图像 1,2 Samsung NP300E5C Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
结论
11等其他人完成本指南。
aliahsan95
于09/23/15注册
937 声望
创作了4篇指南
团队
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G13
3 名成员
创作了4篇指南
2条评论
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - 回复
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 56
总计 12,458
