跳转到主内容
Samsung NP270E5E-K03US RAM Replacement
你所需要的
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: 步骤 1 中的图像 1,2 Samsung NP270E5E-K03US RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: 步骤 2 中的图像 1,2 Samsung NP270E5E-K03US RAM Replacement: 步骤 2 中的图像 2,2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: 步骤 4 中的图像 1,3 Samsung NP270E5E-K03US RAM Replacement: 步骤 4 中的图像 2,3 Samsung NP270E5E-K03US RAM Replacement: 步骤 4 中的图像 3,3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: 步骤 5 中的图像 1,3 Samsung NP270E5E-K03US RAM Replacement: 步骤 5 中的图像 2,3 Samsung NP270E5E-K03US RAM Replacement: 步骤 5 中的图像 3,3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: 步骤 6 中的图像 1,1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
结论
另外一个人完成了本指南。
Kyle Golden
于03/23/17注册
353 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,078
