跳转到主内容
Samsung NP-QX411L Hard Drive Replacement
你所需要的
  1. Samsung NP-QX411L Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Samsung NP-QX411L Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
  2. Samsung NP-QX411L Hard Drive Replacement: 步骤 2 中的图像 1,2 Samsung NP-QX411L Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
  3. Samsung NP-QX411L Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
  4. Samsung NP-QX411L Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
结论
另外一个人完成了本指南。
Rebecca Johnson
于02/17/17注册
561 声望
创作了5篇指南
团队
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 1,503
