跳转到主内容
Samsung NP-NC10-KA02US WLAN Card Replacement
你所需要的
  1. Samsung NP-NC10-KA02US WLAN Card Replacement, Battery: 步骤 1 中的图像 1,2 Samsung NP-NC10-KA02US WLAN Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 2 中的图像 1,1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 3 中的图像 1,1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US WLAN Card Replacement, Back Plate: 步骤 4 中的图像 1,1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 5 中的图像 1,1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 6 中的图像 1,2 Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 6 中的图像 2,2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US WLAN Card Replacement, WLAN Card: 步骤 7 中的图像 1,1
    • Using a 3.93mm Phillips screwdriver remove the screw attaching the WLAN card.
  8. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 8 中的图像 1,1
    • Gently lift the WLAN card.
  9. Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 9 中的图像 1,2 Samsung NP-NC10-KA02US WLAN Card Replacement: 步骤 9 中的图像 2,2
    • Gently using a plastic opening tool, remove the two latches attached to the WLAN card in the netbook.
    • Your WLAN card is now removed.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 1-1, Sullivan Fall 2016 USF Tampa, Team 1-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 470
