跳转到主内容
Samsung NP-NC10-KA02US RAM Replacement
你所需要的
  1. Samsung NP-NC10-KA02US RAM Replacement, Battery: 步骤 1 中的图像 1,2 Samsung NP-NC10-KA02US RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US RAM Replacement: 步骤 2 中的图像 1,1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US RAM Replacement: 步骤 3 中的图像 1,1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US RAM Replacement, Back Plate: 步骤 4 中的图像 1,1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US RAM Replacement: 步骤 5 中的图像 1,1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US RAM Replacement: 步骤 6 中的图像 1,2 Samsung NP-NC10-KA02US RAM Replacement: 步骤 6 中的图像 2,2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US RAM Replacement, Fan: 步骤 7 中的图像 1,2 Samsung NP-NC10-KA02US RAM Replacement, Fan: 步骤 7 中的图像 2,2
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US RAM Replacement: 步骤 8 中的图像 1,1
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US RAM Replacement: 步骤 9 中的图像 1,1
    • You are now able to carefully detach the fan from the base.
  10. Samsung NP-NC10-KA02US RAM Replacement, RAM: 步骤 10 中的图像 1,1
    • After detaching the fan, you are now able to remove the RAM by extending the two side bars out
    • During this process, the computer needs to be shut off. Other components could be damaged and the computer would not be able to recognize the RAM properly.
  11. Samsung NP-NC10-KA02US RAM Replacement: 步骤 11 中的图像 1,2 Samsung NP-NC10-KA02US RAM Replacement: 步骤 11 中的图像 2,2
    • With the bars extended, you are now able to slide the RAM off the base.
结论
3等其他人完成本指南。
JHOAN USECHE
于10/03/16注册
372 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Sullivan Fall 2016 USF Tampa, Team 1-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 375
