跳转到主内容
Samsung NP-N145-JP02US Screen Replacement
你所需要的
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: 步骤 3 中的图像 1,1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: 步骤 4 中的图像 1,3 Samsung NP-N145-JP02US Screen Replacement: 步骤 4 中的图像 2,3 Samsung NP-N145-JP02US Screen Replacement: 步骤 4 中的图像 3,3
    • Using your fingertips, gently pull screen to pop it out of the frame.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 417
