跳转到主内容
Samsung NP-N102S-B05PH Speaker Replacement
你所需要的
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: 步骤 2 中的图像 1,3 Samsung NP-N102S-B05PH Speaker Replacement: 步骤 2 中的图像 2,3 Samsung NP-N102S-B05PH Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: 步骤 3 中的图像 1,2 Samsung NP-N102S-B05PH Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: 步骤 4 中的图像 1,1
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
结论
Lennon Grimm
于10/04/16注册
247 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Nance Fall 2016 USF Tampa, Team 2-4, Nance Fall 2016 的会员
USFT-NANCE-F16S2G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,089
